Scout II T-18 trans (V-8)
T-18 4-speed transmission from a '75 IH v-8. Worked fine before removal. Clean exterior. $100. Will throw in the Dana 20 and input gear for an extra $50. In sonoma county, calif.
The clutch pedal and linkage are also available for free, with the trans, if desired.
What tranny is the t18? I am looking for a 4 speed tranny to fit a IH 304 that will be good for raod use. I do not want the tranny with the low 1st granny gear that is a non syncro gear. I would like all 4 useable gears on the road. Thanks walt
