Scout II project parts/whole
mrmike
Scout II chassis: 345 4bbl/auto/d20/d44 GM 8-lug full width front, already cut and turned with spring over steering, needs welding finished, 4.10/ d60 ff rear with GM discs, diff turned, original 4.10 gears, needs welding finished / steering and rear brakes hooked up / towbar not included / take it all or parts can be priced and bought seperately
let's start at $1000 for the whole thing. Trades and offers considered. You know how much is involved with doing a SOA properly.
Also have new 5.13 gears and lockers for axles that can be bought seperately. Also have a shackle reverse kit for the front springs that is new and can be bought seperately.
Can email as many pics as needed. Mike.hoffine51@gmail.com
Call or text : 7six5four2seven3eight8four
located near lafayette, in.
Took a short video of motor running on carb cleaner. Motor sounds quiet and tight. Has a quadrajet 4bbl that will need work. Fuel pump May not be any good... Would not pull fuel from gas can???
Some new pics.
I know cash is tight for all, but I will trade for gun/s. About anything hunting. Also looking for a slide-in truck camper. Can be an older camper in need of work. Just don't want a rotted mess.
As of right now, the axles have been traded.... For a nice honda generator. Will still have the motor/trans/tcase in the frame with springs. Someone come buy this stuff soon because I will get tired of mowing around it..... :d
Axles, gears,lockers gone. All that's left is a good 345 long block with all the accessories, no intake manifold. A good 727 auto with a d20 attached. A solid frame cut off behind rear shackle hanger with stock springs. Make offers on stuff. Make it better than scrap and worth messing with.
