vancetater
Ok here are the specs I have a 72/75 Scout II on 3/4 ton Chevy axles (hd 44 with disc up front 14 bolt drum in rear). I have brand new calipers, pads, rotars up front also new braided steel lines front and rear (new) the rear drums within spec and good wheel cyl. I recently replaced the master cyl and I have same issue my peddle has pressure and it stops fine but the pressure is at the bottom almost to the floor and when I go in water or mud it just fades to floor I know this is normal in the water and what not but I would like to have a higher peddle. Im wondering if I need to change my master cyl to a different style like a 1 ton Chevy or something I have tryed adjusting freeplay and the rod inside the booster and no luck what so ever
