Scout II Brake Distibution Block/Tee
rackolamb1
I recently picked up a 1980 Scout II traveler and I am in need of some misc parts.
The main part I am in need of right now is the front brake line tee/distribution block and banjo bolt. (it connects both front brake lines to the proportioning valve).
Some other parts I am in need of are:
throttle cable
windshield washer reservoir and pump
radiator overflow tank
taillight housings and reflectors
turn signal housings and reflectors
front and rear side marker lights - housings and reflectors
front e-brake cable with hardware to connect to rear ebrake cable.
Thanks in advance,
sean
