I can tell you they have different part numbers, and are shaped quite a bit differently where the brake backing plates mount, probably due to the drum/disc difference. Have a couple of 44 knuckles off in the garage and a d30 housing without axles in the backyard, and compared them. There are few other noticeable differences as well, so the answer is most likely not.
