Charles Brown
Mayben knows the story of irmatrude, and the latest episode, wherein she attempted seppuku by spontaneously hot shorting from the battery side of the horn circuit into the portion of the wiring harness running to the front clip, while left unattended in a parking lot.
Now that I'm reconstructing the wiring harness, is there any reason not to wire the horn relay into the "downstream" side of ammeter, I.e. The charging circuit, where use of the horn will be indicated by the ammeter (just like the lights) as opposed to the factory architecture of drawing from "upstream" of the ammeter, where horn use is not reflected on the gauge? How many amps does a horn draw?
Charlie
Charlie
