I have a '63 Scout 80 152, when I got the truck all it had in it as far as parking brakes was the handle I have now purchased all the necessary parts and I am wondering if somebody could throw up some pictures of the underside of the truck with the parking brake installed (routing, where the two cables connect and how, where the lever between the two cables mount).
Also I purchased all the parts from barnes IH and the parts guy said that the parking brake uses a separate cross member that mounts to my frame and he sent me one but I can not find any evidence of tabs on my frame rails to mount it, however there is a little bracket off of the transmission crossmember is that where the lever mounts? Or do I need to weld some tabs in for the cross member? I will post some pics here so maybe people can tell what I am talking about.
Thank you
here it the crossmember and lever
Here is the bracket on the trans crossmember
Thank you
