Scout 80,800,A,B Hood Lift Strut Kit
isasih
Isa's International Harvester
new product @ Isa's IH
Btl (built to last) hydraulic hood strut kit for all 1961-1971 Scout 80,800,a,b
this is an awesome product!:thumbsup:
Isa's International Harvester: Scout 80,800,a,b hood lift strut kit
No more needing to wrestle that heavy hood up and struggle with the prop rod.
Lifts your hood up for you and securely holds it in place until you are ready to close it.
Simply unlatch the hood, give a slight lift and let the struts do the rest.
To close, simply pull down on the hood brace from either side and let hood drop to latch.
An excellent helper for those of you with a lifted Scout 80 or 800,a,b.
Upper brackets install with stainless steel button screws & lock washers for a clean finish.
Lower brackets utilize original fender bolts.
Includes all necessary brackets,hardware and instructions.
Simple install time of 30 minutes.
(brackets come unpainted)
