284International
I have a 1956 s120 4x4. It has a Dana 44 front and the IH rear axle, with the big 6 lug bolt pattern.
I just got the vehicle running well, and now am ready to dive into the brakes before taking it for a test run. The previous owner said it would need a new master cylinder; so far everything he's told me was accurate so far as I determine. My plan is to replace all the hard and soft lines, wheel cylinders and shoes on this 4 wheel drum system, along with the master cylinder.
I want to go to a true dual circuit master cylinder, just for the safety factor, since I intend on making this frequent and regular driver on fairly busy roads. I'm not especially worried about the drum brakes per se, but since I'm going to be replacing things anyway, I'd prefer to go to a dual circuit system.
The master cylinder on these is kind of frame-mounted. Are there good choices for a fairly simple to adapt dual circuit drum brake master cylinder?
I have a hydrovac setup that came with the truck but not attached, if that is helpful/beneficial in the conversion.
If need be, I can fabricate and weld a bracket for another style of master cylinder, if it will merely clear everything and fit into the spot. The preferred option, obviously, would be to find something that's more or less bolt-in.
Thanks for the wonderful forum, I'm glad to be here.
