Hi,
1975 Scout II 345 holley 2210 (newish probably 5 years old), new DUI ignition system.
I live in the city, right front brake froze up, didn't really have anywhere to work on it, so it sat for about a year. found some time, pulled the wheel off, hub was sheared in half. Replaced all that. Pretty grumpy starting after a year of not being touched. Drove it to put fresh gas in it. Very unhappy on the way to the gas station. Drove around a bit to try to get the old gas through the lines. Idled ok, didn't want to accelerate. Stopped by my shop, stalled in the parking lot, wouldn't restart. Upon inspection, wires to starter all melted from bad connections. Replaced main posative from battery, new connectors on the rest, wire wheeled the starter connections. Fired right up.
At this point, still ran real lousy. coughing and stalling when giving it gas. I ran a can of carb cleaner through the carb while it was running (float bowl vent). Adjusted accelerator pump linkage. Now runs great in park or neutral. Excellent throttle response, starts on a dime. As soon as I put it in gear and try to give it gas it stumbles. It is currently stranded in the parking lot of my shop. Current plan is to run another can of carb cleaner through and try to limp it back home (only a city mile of side streets).
It ran pretty good before I neglected it, so I am guessing gummed up carb and bad fuel? I put a fuel treatment in the tank with 10 gallons of fresh gas, been trying to get some of that to run through there. I suspect my accelerator pump was gummed up before cleaning, it was really sluggish (the actual pump plunger, not the acceleration).
Any other things I should be looking at here? Any advise to get the thing home?
Thanks for the help,
Nick
Nick
