I have 1970 Scout 800a, 4 cyl 196, 4wd, 3spd, holly dist, mechanical fuel pump. The Scout was parked for about a year beforfe I bought it, I primed it a few times and it appeared to run fine. Suddenly it started dying out after it warmed up and at higher rpm or under load. I changed the fuel filter, and dumped the bowl on the bottom of the fuel pump. I had to prime it again 3 or 4 times to get it to run, but the problem persists. If I pour some gas in the carb, it starts and runs again for a little bit. It idles fine. Could it be the fuel pump? What else could it be? Any suggestions?
One other item, I did replace plugs, wires and distributor cap just prior to this starting to happen, but I don't see how this could relate.
