Round Gauge Overlay
78SSII
I have a couple questions about the dash overlay for the round gauges.
The first one is I assume it come with mounting holes already drilled so it can screw to the stock locations? I dont happen to see any holes in the picture.
Second, is it possible to get the dash without the center hole where the clock goes?
Finally, is it possible to have a round hole placed where the radio will go along with smaller holes for rocker switches? Is it possible to get a dxf file to manipulate and then send back with what I want?
Thanks,
bill
If you want a custom dash you May want to purchase one of the blank panels that we have available although I'll warn you that cutting/drilling thru stainless steel is not easy. If you want to try and order a custom panel contact IH only as they have these made - 661-728-9552.
