So I tore apart my 196 rocker assembly; it was quickly apparent that the shaft is too worn to reuse! Then I remember the 152 core I have that was much cleaner looking. Instead of the propane torch and dead blow hammer necessary to remove the shaft stands from the 196, the 152 rockers and stands just slid right off! The photos tell the tale, and I feel I can run the 152 rocker assembly (after pulling the end plugs and scrubbing all items clean). Then I look at this post
And I don't think my better shaft looks as nice as the "useable" shaft in mm's pic. Mind you, I've not cleaned it with a wire wheel or emery cloth yet, just wiped it down. I can just feel a bump at the center of each rocker wear area, but the bump is not a ridge. Thoughts?
Also, the better 152 rocker assembly has much nicer rocker bushings (as expected). I notice that some bushings have deeper oiling groves than others. The attached photos appear to be the most extreme difference. Is this acceptable? I've not ordered the service manual; is there a spec for the shaft minimum diameter, and/or the bushing maximum diameter?
I'm tempted to clean and reuse this assembly, but I'd appreciate some feedback. This will be going into my past/future daily driver, so I'd love it to last for 50k miles or more...
Thanks to all and to IHPA!
