jauringer
Well, I was able to take my passenger side (9 stand, welded type) rocker assembly off last night and the news wasn't so good. Nothing was plugged at this point in time, but it was obvious that it had been plugged at some time over the last 39 years.
My rocker shaft is toast. Most of the shaft was only slightly worn. There were a couple spots that would have passed for reuse, but then the rocker closest to the front looked like it was starved bad as the shaft was eaten and scored terribly.
I cleaned up all the stands, arms and spacers last night and went through everything and I was hoping to get a few questions answered so I know how to proceed here.
All but two of the bushings measured out with in spec. One was badly damaged and one was .005 out. (.870)
1. I can get shafts and arms from ihon, right?
2. I had two arms that had a loose valve pad. (not in/out loose, but it can be slightly twisted. Can these be used as is, repaired and used, or do they need to be replaced?
3. The push rod end on all of the arms looked good somehow but there is some wear on all the valve pad. The manual references grinding no more than .010 to smooth the pad but I have not way of measuring the wear correctly. I can feel most of them with my fingernail. Any tricks?
4. Lastly, I will obviously be replacing parts here and the manual talks about increased valve train length. It sounds like I'll need to remove the lifters and clean the varnish so the plunger can move freely in the new spot? Is this correct?
5. I've read about these nylon pellets used to hold the assembly down. My bolts had no nylon on them and are just standard grade 5 black bolts. Am I looking in the wrong spot here?
Considering the situation, I wonder if it's not just better to get a two "new" assembly's from ihon. I would just need to know what else needs to be done since I'll be replacing so many parts.
Thanks a bunch for the help. I'm about to pull the driver side and report back with that damage as well but I imagine it's no different.
Jason
Jason
