Rocker Arm Adjustment 266 V8
1960B100IH
How do you adjust Rockers to add pre-load? Unlike Chevys, the IH Rockers are attached via a bolt vs a nut that allows the addition of a pre-load? Is this not possible with IH motors or is it somehow adjusted in the lifters? Thanks in advance.
rebuilding and pulling the heads. currently no vertical movement in the push rods but was curious how to adjust if needed when reassembly or sometime in the future. Where would I locate shims? Thank you.
With hydraulic lifters there shouldn't be any lash. Unless you're decking the block and shaving the heads to increase compression ratio you should be fine.
When you grind the cam, the base circle becomes smaller. No, you don't sand the pedestals. We have longer pushrods in stock at IH Parts America.
To accurately set lifter preload you really need to start with a adjustable pushrod, I made several from old p-rods. Get the zero preload P-rod length, then add a minimum of .025 or .05 to the base line. Like Zaedster wrote, reducing the cam lobe base circle will reduce lifter preload. Rebuilding the heads requires regrinding the valve seats and valves, that increases lifter preload by a factor of the rocker arm ratio(1.8-1.65-1. The increase in installed valve stem height after the rebuild X the rocker arm ratio will give the increase in lifter preload. Same as decking the block and resurfacing the cylinder heads increases lifter preload 1-1. What I am getting at is that unless you plan to go wild with the cam and making some major changes in the engine geometry, you will be ok and avoid a preload issue. If you have any ticking after running the engine in, than verify the loose lifter and increase the p-rod length.
