robert shaw thermostat
int77345
does the Robert Shaw thermostat have some sort of bypass that allows a small amount of coolant to flow the the radiator even below the 180 degree set temperature. it is taking my scout greater then 45 min to reach 180 degrees when the out side air temp is below 30 degrees
from a clold start i reach 130 degrees quickly then 130 to 180 takes forever. costing down a long hill temperature will go decline from 180 and rest on 130 never going below 130.
seems some coolant is flowing to the radiator below the 180 temp???
ihpartsjeff
Administrator & Owner
Staff member
You may have to pull the thermostat and make sure it is not stuck open. When it is closed the thermostat is in bypass mode and the coolant circulates only thru the engine so it should not get any colder .But yes I have seen the engine temp drop on a long decline on a cold day.
int77345
thank you for the reply !! i will take it out and have a look some time in the next few weeks.
out of curiosity do thermostats ever fail half open ?
Hondo
Pot of water on the stove is a good test, put it in the pot and verify where it opens with a meat thermometer or similar device.
Robert Kenney
Super Moderator
To elaborate further, the RS thermostat has a cup that moves as it opens and closes, the inner surface of the cup is sealed against a ring that is in the center of the thermostat. That seal can leak and impede the engine reaching running temperature. This symptom can occur even it the stat opens and closes perfectly. Had 2 cheapo stats in a row do this, installed the old RS and it was fine. This is in the frigged South of California. :winky:
Richard
well, as proof is in the pudding (so to speak), I too went from the RS thermostat to an aftermarket el cheapo. I wanted to go from the RS 180 to a 160 as I live in So Cal, and it has been very hot of late. Had cooling problems from the get go. This is a recently rebuilt 345 (600 miles on it) after break in. I was freaking out because I was hitting 195, 200, 210, on my mechanical temp gauge. No Bueno! Changed out the coolant, changed out the fan clutch, but no good. After reading up on the RS thermostat, i see the difference! the flow opening is way bigger that the aftermarket el cheapo is. Went back to the RS thermostat (180) and presto! I drove around yesterday in 100 degree weather: temp gauge never got above 195. When I stopped to get lunch, came back to my Scout, started it up, temp gauge showed 205, then quickly came down to 185! Amazing! simply fricken amazing!
It is what it is.
FDChappie
Active member
In my investigations there are some thermostat housings that have a small hole that will work with non-RS thermostats and some with a big hole that absolutely require a RS thermostat.
