Hey all,
I have a conventional lifting shackle up front and had to use 7 degree shims to get me to 0 /+1 degrees of caster. My pinion angle is now a joke.
My question is, if a reverse shackle is used does it keep the "stock" caster / pinion angles somewhat the same as before the reverse shackle kit was installed?
Not sure if I have this right in my mind but the kit looks like it might have the same distances (spring eyes to frame) for both the front fangs and rear shackles to keep the axle from rotating much once installed????
If there is a change in caster/pinion angles is it less than a conventional shackle lift? That way can you get away w/shims and a c.v. Front drive shaft instead of doing a cut-n-turn? Jeff says you will need a longer front drive shaft w/the reverse shackle kit anyway.
