codeman
Has anyone assembled (welded) the fangs and tube together and installed the unit as an assembly?
My bare frame is upside down right now on benches. I've been beefing up body mounts, spring hangers, etc. Preparing for a SOA. I had a thought about welding the fangs & tube up as an assembly then installing that to the frame. I have a known flat surface that would allow everything to be flat and aligned and could easily hold the width to the specific dimension.
Any thoughts, pro or con????
