reverse lights continuously on.
Android2887
I recently acquired a 68 1100c pickup witha 344 and automatic transmission. the previous owner has ran a fairly large gauge wire from the taillight straight to the starter. after crawling around underneath the pickup searching on the transmission for the NSS I was unsuccessfull. I'm at a loss what am I missing?
FDChappie
Active member
I can't tell anything from the pictures, however a heavy wire going from the starter to the back of the truck is usually going to an RV trailer plug. Some RV's do have backup lights, so a short in the RV plug might cause this.
That year of truck should have a Borg Warner 8, which IH referred to as a T-28 and listed as code 13028 on line setting tickets and service literature. It does not have an NSS mounted in the trans housing as does the Chrysler Torqueflite 727 units that IH used in later model year vehicles. The NSS for the BW8 is actually attached to the lower portion of the steering column and is actuated by your column mounted shifter. It is IH p/n 261902C91.
