removable top interior trim panels
codeman
I've just started my build on a 78 Scout II. The top interior trim panels are there. They're dirty but otherwise pretty good. Both have small cracks/tears at bottom rear curve for the window. I'm thinking get them straight and has flat as possible and laying them up with glas from the back side???? Going to be working on various things over the winter and hoping to have the body ready to come off by spring.
We've had good luck using abs cement with the fiberglass instead of resin on aircraft interior plastic. I believe they're all made of royalite or abs plastic. Good luck.
One of mine was cracked and I just scuffed the backside with 80 grit and used a little longstrand fiberglass from evercoat, ill just say its probably the strongest peice on the truck
