thanks for the responce! I guess I talking about the sensor that goes next to the reluctor? I found one on an old junkie and I going to put that on today I hope, and see if this will help me get my terra running if not I'm going to get the ho-181 kit to put in. I would like to get a little use out of the gold box that I paid dearly for; before, I change over to the pertronixs? I've got great spark at the cap but nothing pass the dizzy; so I'll keep mess'in til I exhaust all of my avenues
This doesn't make any sense. Follow the "high voltage" (secondary output) path....
The coil interfaces on the secondary side through the rotor as it "rotates" and distributes a secondary output signal (the "spark") to each terminal inside the cap in firing order sequence. The high voltage signal is then directed to each spark plug electrode in turn by the spark plug cables.
So...you must have a healthy spark (at least 3/8">1/2" nice fat blue spark) when a plug wire metallic connector is held adjacent to an engine ground point. If it will fire an "open air" gap of that width, then you do not have a secondary output problem! Test each spark plug metallic termination in sequence as the engine is cranking over. Then back up and replace the cable from the coil to the distributor center terminal and test again.
A Holley distributor rotor does not incorporate a resistor inside it's construction. It is s simple direct current path with no added resistance.
A prestolite electronic rotor does have a "resistor" incorporated inside it's construction, I have posted pics of that in another thread....but, those rotors are in no way interchangeable on the various distributors. In the case of the prestolite rotor, they can and do "go bad" due to failure of the internal resistive element or the riveted connection which holds the assembly together...or the brass tip simply erodes due to conducting continuous high voltage over time and the tip "arcs" in the air gap between the rotor tip and the distributor cap terminal. That internal resistance of the rotor is a design element of the prestolite electronic amplifier (same purpose as the gold box) and is an absolutely necessary for it's continued functionality over a long service life.
Of course...even a new gold box can fail! Have you simply swapped another known good gold box onto the system for testing?
The most likely "fail" point for any gold box system is the actual wiring harness and the connectors used. That means the entire wiring system for the entire ignition system! The male/female connection points must be absolutely clean and bright with no measurable resistance due to oxidation/corrosion and should also be doped with dielectric grease.
I've never found or seen an actual "failed" sensor/trigger assembly, the problems with these systems are always with either the wiring or the gold box amplifier itself. And in the case of "repeated" gold box/amplifier failure, the problem is always the wiring and connections that wipes out the amplifier itself. Failure of the amplifier over time is normally due to the location at which ihc mounted it and the resulting "heat soak" over time.
