Ok guys I am rebuilding the top end of my 345. One of the freeze plugs failed and going to replace them all. Also she is burning oil at a pretty good rate as well, will I be able to tell if the oil is being burn thru rings or valve?
I will be replaceing the water pump while I have it apart, do I need to replace anything else while I am down that far??? I wil be ordering the gasket kit(heads and rest of motor)
I have the sevice manual for the tq specs. But just want to confirm a few things that are bugging me.
1. Does the dizzy have to come out to pull intake (1972 enginei am assuming original)
2. Do the lifters and pushrods for each cylinder have to be returned to same cyl and position?
3. Do I have to drain cooling system before I pull head?
4. When retotqing heads do I use the numbers from the manual?
5. Anything I need to be aware of when I pull heads??
Thanks guys I appreciate all the help.
