Hi to all.I got a 72 s2. When I was pulling the rear mounts I noticed the top of the frame on both sides was bent down is this normal? Should I bend it up straight with the frame or leave alone ?
You need to post good clear pics describing your situation as found, not "cellcam" pics. We need to see if the actual frame is out of alignment or the body support/mount portions of the body.
you need to post good clear pics describing your situation as found, not "cellcam" pics. We need to see if the actual frame is out of alignment or the body support/mount portions of the body.
