kyleandhisIH
I haven't looked closely (mostly because I know I'd try it) but I have removed my distributor and checked end play. Using a small 6" machinist's rule, I witnessed ~0.046" end play and tried to take a picture. Unfortunately, my camera isn't capable of fine detail.
What do I need to know before getting some shims and trying to pull the gear? Should I use some kind of tool? Maybe cut a hole in a board, split it, and nail it together around the shaft?
I figure if I can get a way to pull the gear and then find a method of safely pressing it back on, I should have no problem sizing the shims correctly. I'm also told a copper-based anti-seize is a good idea, but where exactly can this be applied?
I haven't gone for a thorough tear-down of the top end, but nothing feels "loose" about the mechanical advance unit, and the vac advance holds vacuum and responds well to signal, performing well with a visual inspection time and time again.
I figure if I can get my timing to "wander" less, having it read 23* btdc isn't so bad. (other posts on the website expound on my specific situation... Regardless, it runs best in the 23-24* area.
