prop valve
elyNV
On the proportioning valve, what is the correct way to press the pressurre valve (not sure the name) down while bleeding the breaks, I fear I might break it......is there anything else I should know before bleeding the breaks ? Thanks !! What are the break going to be like if that valve is not pressed during the break bleeding process? Thanks many!!
