Soft_Click
1966 IH 1200A Pickup, SV304 engine with 4-speed T98 transmission.
I finally got my timing dialed in and carb tuned nicely so I’m idling at 18 vacuum. Starts and idles great, accelerates immediately and revs pretty high. Haven’t really pushed it to the limit.
I went for my first (somewhat) successful drive since I bought the truck, which was a rush. Unfortunately I couldn’t really accelerate beyond 10 mph. My engine would speed up, but the wheels wouldn’t.
I’ve already pulled the transmission and inspected the clutch which seems to have plenty of life (see attached). I also got the flywheel resurfaced and reassembled everything.
I couldn’t loosen the bleeder nipple on the slave cylinder and stripped it even with my wrap around wrench, so I replaced it. I adjusted the clutch linkage so there’s no play at all.
I think it’s both not releasing the clutch all the way and not engaging all the way somehow.
Some potentially relevant symptoms:
Engine idling, everything warmed up. Clutch in, wait a few seconds for transmission to stop spinning, grinds into first gear. If I got second then first, no grind. It’s still spinning I think.
Rolling downhill in clutch pedal depressed in neutral and there’s a distinctive whine I haven’t seen before. Maybe the engine being driven by the wheels?
Clutch only engages right at the top. I’d really like it engaging closer to the bottom of the pedal stroke.
The big on of course is I go to accelerate and it grabs initially, then seems to slip above 10mph.
Any ideas?
Any ideas?
