Robert Kenney
Super Moderator
I wanted to post an up date on tim potters engine. For those who are not familiar with the saga.
This ihon thread documents a bit of the deal and some of the research.
http://www.forums.IHPartsAmerica.com/gas-engine-tech/1024-sv-series-timing-Mark-variation.html
The engine was supposedly rebuilt by a portland based engine re-builder. From day one it has been plagued by problem after problem. After working through the head gasket leakage he was never very happy with its performance. Low manifold vacuum, bad gas mileage <10 -11 mpg very soggy low rpm power. I was never satisfied with its idle quality as it seemed to have a limp or two. One thing it seemed to point to was retarded cam timing. The cam while bigger than stock it was still not any bigger than the average rv cam.
It all came to a head after the engine developed a series miss and loss of power while driving up the grapevine a couple of months ago. A vacuum gage showed some serious problems with severe fluctuations in vacuum.
This week end some dedicated scouts west members helped tim yank the motor with the intent of giving it a complete tear down and diagnosis in my shop. We pulled the heads to have a quick look...
to say we were surprised would be an under statment...
First thing is broken valve spring on #2 intake..
Second was a 1/4 inch wide notch burned into the exhaust valve on #7 (picture below) that cylinder was not working very well.
third, the same valve and 4 others that I pulled for a look had severe seating surface wear grooves that would not have been there at only 17,000 miles, even 150,000 miles would show less wear if ground when the heads were really rebuilt.
Fourth, and probably the worst, all eight cylinders had severe scoring from inadequate ring end gaps from the start. They most likely didn't bother to even check.
Fifth, we checked the cam timing and like we thought it was installed 6 degrees retarded. I guess we need another offset cam key.
Tim asked that the heads and block be milled to achieve 9-1 to match the cam. I will need to cc the chambers to verify them but the block was never touched. In fact the factory size stampings were still fresh and had been media blasted but never machined. Pistons .040 in the hole ( below the deck)
I will update with more info after the tear down as low oil pressure was another issue. I hope the crank is ok.
