pineneedle
I am in a quandry: I am setting up the pinion bearing preload in the Dana 44 in the rear of my '67 Scout; the book calls for 10-20 in/lbs for used bearings, and 20-40 in/lbs for new. I am installing timken bearings (from the kit I bought from you folks). If I add the thinnest shim to the pack I get about 19 in/lbs resistance, and if I subtract this thinnest shim, I get 42 in/lbs. So, my question is: is it better to go with the slightly low (shim in) or the slightly high reading (shim out)?
Pineneedle
Pineneedle
