Well then, my '75, which is a 1 ton 4x4, needs a front right fender.
I have a front left fender from a '73 1210 camper special. The differences are easy to overcome, in my opinion, and it seems to fit my truck well. The longitudinal brace/rod attaches to the air box with a bracket in the rear, and to a bracket up front, which will require one hole to be drilled in the fender. The rear lower needs a 3" x 5" sheet metal plate welded to the bottom of the fender so that it will bolt to the rocker extension with 2 bolts. All other attachments and holes are the same as the '75.
The inner fenders (left & right) bolt right up, the only difference is the shape of the bottom edge which doesn't affect anything. The rubber splash shields attach and fit perfectly. Hood mounts, battery box, etc. All mount the same.
Anybody out there have a good front right fender for a '69-'75 pick-all?? I am looking to buy one, thanks.
