As we discussed on the phone per turn signal switch-male connector will not fit in female connector. I also found the turn signal lever to be too wide to fit and if pressed in it is highly likely the housing will break. Let me know what I need to do in regards to myself being an idiot on installation or do I have the wrong turn signal switch-god speed.
1977 IH Scout ss2 with build date of: 04-21-1977
345v8 w/727
non-tilt column
You can see the electrical connector has no chance of fitting-note how wide alignment slot is on old connector
Subsequent side of electrical connector-note how wide alignment slot is on old connector
Turn signal lever
Your package part #
345v8 w/727
non-tilt column
Turn signal lever
Your package part #
