kastlerock
I am looking for advice on selecting all the correct components for the suspension and steering on my 73' Scout. I would like to go with a little lift, keep the SUA and will be replacing (atleast) the front drums with disc brakes. I will probably be using a tire no larger than 33s. Here is what I am thinking:
Skyjacker
-4” lift
heavy duty u-bolt kit
-CPT-SUA-uboltplt-kit
heavy duty shackle kit
-CPT-shackle-kit-5
body bushings
-sii-bod-bush-kit-poly
front shock tower kit
-CPT-shock-tower-kit-dex
Bilstein shocks
-5100 series?
Heavy duty rubber bumpstop
-CPT-bumpstop x2
-plus bolt on brackets x2
castor shims (4*)
-shim-2
-center-pin (5/16th or 3/8th?)
pitman arm, hysteer arms, etc.? Not sure if any of these will be necessary
my tie-rod and drag-line will be needing replacement as well and so I was curious what you guys might recommend. Currently, I have a stock Dana 30 for the front axle. Should I consider any other parts/components for this? As I have mentioned elsewhere, this is my first vehicle restore so any assistance would be greatly appreciated.
Thanks,
david
Skyjacker
-4” lift
-CPT-shackle-kit-5
body bushings
Bilstein shocks
-5100 series?
-CPT-bumpstop x2
castor shims (4*)
-shim-2
Thanks,
david
