Michael Dimock
IH Parts America Sales Assoc.
Okay, I will be putting a Scout 2 196 in my Scout 80 and it has a 11 inch clutch. This clutch needs to be rebuilt and I need to get an 11 inch clutch disc with the 15/16" 10 spline input shaft disc in an 11" version for my pancake bellhousing s800 4spd. I have 2 good 10 inch clutches but the correct flywheel for the 196 is only drilled for an 11 inch clutch.... Okay, to simplify it, what should I do? I have 6 flywheels, 4 are 4cyl and 2 are v8's. I think all but 1 are able to take a 10 inch clutch. Should I:
1. Swap flywheels around and hope that one is close to the same weight so I can run my rebuilt 10 inch clutch.
2. Run a 10 inch disc in a 11 inch clutch....
3. Try and source an 11 inch disc that will work or find someone to swap center sections.
If 3 is an option... Can a 11 inch clutch physically fit in a pancake bellhousing?
4. Have a machine shop redrill the correct flywheel for a 10 inch clutch.
5. Other?
As you can see, I am at a loss here and need some expert help.
5. Other?
