Chad, Jeff thanks for the response.
I have been pondering some sort of performance upgrade to achieve better highway performance without totally destroying my offroad capabilities. Pretty fine line to walk, but even harder with the sd-33 it seems. My current drive train includes: sd-33t with elbow eliminator and 3" exhaust, cr t-19, Dana 300, 3.73s, 33s. These are some of the options I have considered:
nv4500 -- see above.
Higher gears & 4:1 kit for the d300 -- I will probably have a set of 3.54s available soon, but that is only a reduction to about .95. Looks like 3.07s would drop the ratio to about .82 -- pretty close to most o/ds. I have thought about this before, but worried about around-town acceleration, which isn't particularly good now. Do you know anyone with 3.07s in a diesel? Not sure, but I think diesels were only offered with 3.54s and 3.73s, but don't have any reference material here to verify that. Makes me think the factory didn't think much of the idea.
Cummins 4bt re-power -- discussions with cory smith suggest I would need a new engine, transmission, tranfercase, drive shafts, and front axle. Probably ought to replace the rear axle, too -- just for sh*ts and grins.
would be a great drive train, but seems a little extreme ($$$).
I suspect there is no good answer, or somebody would have done it already. That pretty much leaves me no where to go but putting a gasser in. Since my diesel is about ready for a re-build, that idea begins to look more and more attractive. To add another wrinkle, we would like to be able to pull a small pop-up camping trailer -- experience pulling a similar trailer in the mountains with the diesel was not fun. I hate to think about trashing the diesel, but I just keep coming back to that answer. If I went to gas, I would be tempted to go 392 -- too much is never enough! Really haven't done much research on gas engine buildups lately, but I think there must be some happy medium between performance and (relative) economy. Daily fuel costs May go up, but I wonder if long-term costs May not be about the same when you factor costs of o/d transmission, custom driveshafts, and engine rebuild. Plus you get a lot more drivability.
Thoughts???
Nick
