NOS 152 Block With 3.750 Stroker Crank and 6.385 BBC Rods
Robert Kenney
Super Moderator
Selling my stroker project build. Starts with a NOS unmodified block. I had a 196 crank professionally welded and offset ground 3.750 Stroke for BBC rods and bearings ((included) and IH main bearings . Will need to chamfer the unchamfered big end face of the rod to clear the journal fillet. It all clears the block.
Block and crank are mocked up. You'll need to have pistons made, the one in the photos was a machined down 396 BBC piston for mocking up.
Numbers on deck were wall thickness readings from sonic testing. Bores are standard surface corrosion is minor.
Asking $450.00 OBO
Located in SoCal, 91750.
PM if interested
