Did a compression check today, and all cylinders looked good except for #5. No compression on #5 at all. Checked valve function and they were working up and down. Put my finger over the spark plug hole and nothing. Dont hear any rachet so I assume the piston rod is it tact.
I will borescope it Wednesday, so dont know what I will find. If its a cracked or hole in the piston, that is obvious, but if the I dont find a trashed piston, I guess its pull the head and look over the valves.
Any other ideas come to mind?
If I do pull one head probably will pull the other and get the valves done.
Are pistons available in singles?
