new sensatrac coilovers on rear
Ok spec are 78 traveler
345-727
Dana 44 front and rear
Dana 20 trans case looks to be a 2" shackle lift might show in my picture post if you can see it if not I can take other photos
31" tires.
Ok I just put a new set of sensatrac rear coilover shocks on the Scout but it raised the rear about 2" and now it doesnt set even. Got the 70's rake which I hate. Is there anything I can do to either add 2" to the front to match without alot of fab work and that is a solid choice or anythin I can do to the rear minus pulling the shocks back off. Maybe cut a coil off the actual shock springs or??? If the front work is recommended im on a slight budget so needs to be a cheap fix if at all possible, thanks
