Using a valve cover cut in half longitudinally, mount it on one side and watch down into the lifter gallery on one side and verify it's flooding the lifter chamber and bores with oil.
As Robert said, your issue is not "the lifters" or the brand of the lifter. Though the johnson lifters are by far the preferred source. Study all the threads in this sub-forum and you will see we've hashed all this out with fact and testing!
And...a lifter can be tested easily for "leakdown". Ihc spent an inordinate number of pages and words in all service references regarding lifter service. Review the process in any IH service manual, the same section was repeated in every service manual, there is/was only one single hydraulic lifter system used in the I-4 ans sv engines, though there were two different suppliers to IH for that part.
We have determined that some iskendarian lifters (those are not manufactured by isky but are a private label deal) were below par in the quality department...in a few cases we found the actual lifter was missing internal components! That was a total anomaly and is certainly not the norm.
Memorize this thread and the attachments contained therein...those diagnostic processes will lead you to...cam bearings! Either incorrect installation (most likely), or trashy galleries. I spend about three hours on the oil gallery cleanup alone in these engines when building one, and that is after the block has been either tanked or bake and blasted. If your oil pressure readings are accurate and taken with a known good gauge, then the numbers you posted are high and out of the range of "normal". Oil pressure readings that are "higher" than the norm are not good for these motors, that is not within the design parameter. The lubrication scheme for these engines is based upon high volume/medium pressure, these are not chryfordrolets and 90% of the mechanics in independent shops today got no idea how to diagnose and deal with lubrication issues.
Most of the time, "noisy" lifters are traced to non or poorly oiling rocker assemblies, a classic example regarding a freshly built engine is described in this thread:
http://www.forums.IHPartsAmerica.com/gas-engine-tech/1016-waynes-non-oiler-392-a.html
