WesChapman
78 Scout terra, stock electrical system.
My old cvr was only producing 1.3 volts average, measured via analog multimeter. As a result, my gauges read slightly low. I ordered a new bwd r307 cvr and installed using the directions from a post on this forum by caperodder.
I believe I connected the new cvr properly. Attached is a picture on my setup:
I reconnected the gauges and fired up the truck. The gauges read even lower now, and I could see the gauges bounce up ever so slightly with each pulse and then settle back towards 0.
I put my analog meter on the output and saw 5 to 9 volts, but the cvr would only pulse once every few seconds. The old cvr would pulse constantly about once per second, maybe faster. The new cvr, pulses, then nothing, nothing, nothing, then 1 pulse, then nothing, nothing, nothing. I checked the input voltage; truck running it's a little over 12v.
Could the new cvr be deflective? Do I have it wired correctly?
