I have taken my 1968 1200C 4X4 down to the frame. I'm attempting to do a full frame off restoration. I wanted to change the axles out to a different bolt pattern so that: 1) I can get away from the split ring and 2) More selections for wheels. SO I purchase a 1971 1210 donor truck. I am almost ready to lift the frame to set the axles under it and start putting it back together. I had failed to write down the measurements when I was removing the original axles from front hub to rear hub, but I'm thinking it was 119". I do have my truck manual but haven't been able to find anything there. Any help would be greatly appreciated.
