Need instruction sheet for Scout 800 hood strut kit
Hey guys, I was there today to drop off an axle housing and purchased a hood strut kit for my 71 800B. Unfortunately the instructions were not included (the box was open) and I have searched your site and ISA's and I do not see the instructions anywhere. If you can point me in the right direction it would sure be appreciated!!
Thanks!!
Well I looked at photos and figured out most of it but now I'm thinking maybe I have the wrong brackets? Here's a photo of my brackets and another photo showing the shock mounted on the upper ball. The ball joint is hanging at it's full pivot travel and it will not reach the lower bracket this way so I'm thinking maybe these upper brackets are for a different model? The brackets in the Stumpy build are L shaped and mine are flat.
Michael Dimock
IH Parts America Sales Assoc.
BrokeGunner,
From the pictures I can find of Royce's Scout with that kit installed on Isa's IH website, the fender bracket is mounted all the way to the rear of the engine bay near the firewall. It looks like you have your bracket mounted one set of holes forward from that. Let me know if that works out for you. Thanks.
BrokeGunner,
Hi Michael, I tried putting the brackets all the way back but the driver side bracket will not clear my washer fluid reservoir. I have attached a photo.
ihpartsjeff
Administrator & Owner
Staff member
The washer bottle has to be moved on a 800A or 800B to clear the hoot strut kit. I either made or modified the existing bracket(I don't 100% recall) on Stumpy and moved the bottle over slightly in order for the hood struts to fit. These are the only two pictures I have on file that come close to showing what was done.
