Need help in troubleshooting, have logged data
Craig
Active member
This is an odd one, the Scout has been parked for a while, figured I had bad gas. New gas and fuel filter. Runs fine at idle.
Fuel pressure at 12 psi which is right were I set it many years ago.
When driving, it surges. The injectors are not dumping in fuel. Pressure looks good when driving
I can rev the engine when parked and its fine. One time it started to run like it did when driving and I can see the injectors not spraying fuel. I ran a can of injector cleaner through at idle just in case. No difference and the spray pattern looks fine
I logged data, but it been years since since I really looked at the data. This really short as the problem happen real fast.
The Scout feels like I'm stepping on the gas and taking my foot off, when in fact I'm not
Craig
Active member
Realized I did not get the blm data, so took it out for a quick run.
But its running way better, no surging.
Will need to test it out more on sat. Attached are the data files
those 137 was in park just warming up the engine
