missing gas tank option for pickup
Sukey
We will likely be in need of a plastic replacement gas tank for our project (1970 1200D 3/4ton fenderside pickup). I was hoping to find a left/driverside cab-fill tank without emissions, and I don't see that as an option. Right now the truck has a metal tank of that description but it is old and gummy and not sure if it leaks or not. The support brackets/straps are rotted out for tanks on both sides. I could do a passenger side tank, but figured it's a bit more convenient when getting gas to have the fill on the driver's side. Is a tank available that would fit that bill?
Zaedster
Future Owner of IH Parts America
Hi,
Driver-side cab fill was not offered from the factory. Only fender-fill for the driver side, while the passenger side has both cab and fender-fill options. The only "Cab/Body" fill options that were offered on the 1969-75' line was the Travelall, as it offered a left-rear tank fed into the cavity within the quarter panel.
Sukey
Hi,
That is interesting, and since I read that, I looked a bit closer at the driver side install and it is definitely more crudely done than the factory passenger side one. I also thought it odd that the gas tank had a date of 1973 on it. You can also see how someone welded the original tank hole up and cut in a new filler attachment
