Drew Merrick
I am purchasing a flaring tool to rebuild my brake lines using an fittings. My brake lines will be mild steel. However, I might as well rebuild the fuel lines as well and I am not sure if mild steel will work or if I should upgrade those lines to stainless. I don't see a problem with mild steel, but maybe you guys have better input into the fuel line material.
Stainless is a much harder material and I would need to spend $75 more on a tool that can flare stainless.
Edit: forgot about aluminum tube as well...
