Mid 1960's 3/4 ton 4x4 IH 1200C hub caps
Robert Kenney
Super Moderator
I am looking for 4 hub caps for my 1200c travelette 4x4. They will all need the hole in the middle. Fronts for the hub and rears for the floater hub. The 1/2 and 3/4 ton caps are different in that the 3/4 ton has a back side diameter of 10 1/4" approx. The 1/2 tone are 8 1/8 approx. Other than that they are the same.. I attached photos of the right one ( but no hole for hub) I borrowed from an ebay member for referance...
In case you can't find ones with the hole, you can make a perfect hole with a greenlee hole punch. If you know a good electrician they might have one in the correct size.
Hi, I have not tried the cap without as don't have one to try.. It is possible they don't need the hole in the rear as the floater bearing hub is a bit shorter than the fronts.. Do you have photos of the axle with and without the cap?
The '68-1200 2wd t'all we had years ago, didn't need the holes in the rear caps for them to fit, an pretty sure they was 16.5 's.Jeff
