Michael you were highly recommended by a member of another forum as the go-to guy for Scout carbs.im not new to carbs but new to this one.background:just picked up a 62 Scout 80 last week,sat x number of years,nobody knows for sure,it ran but poorly,fuel leaking from bowl gasket.picked up carb kit #25577 from napa and proceeded to install it,reinstalled carb and it ran,better but gas was pouring out of the overflow hole above the bowl.after reading you posts here I adjusted the float and it ran but wont stay running,I can get it to start but I have to nurse the throttle and play with the choke,it wont go to high rps,dies when I try,backfires,coughs ect.I have tried several different float settings,as well as air/idle mixture screw settings,seems I have only manged to make it run worse or not at all.do you think this carb just sat too long and is toast?I took some pics hope they help,thought maybe the carb might be missing a part all together.id appreciate any ideas you have and if you think this is something that requires you magic let me know,plz and ty.btw the list # is 2494
Heres a pic of the parts I removed,I didnt install the new needle and seat because the needle appeared to be much shorter than the original...
