Mchanical oil pressure sender
Roughing it
Ok im sure this has come up maby somon and point me in the right direction, I have autometer antique beige gauge mchanical oil pressure, im trying to match a sender to convert from electical. What sender should I get, Scout 80 152ci.
Thanks guys,
rob
A mechanical oil pressure gauge does not have nor require a sending unit. Plumb the gauges pressure line straight into the engines block where the previous sending unit was.
It sounds like you are trying to install a mechanical oil pressure gauge, which means you don't need a sender. You are looking for a kit with small plastic or copper tubing, and the tubing compression fittings for the engine block and the back of the gauge (gauge should have the fitting already). Make sure the tubing does not touch, or come too close to your exhaust when you route it.
Yeah. I didnt like that clear tube the thought of it blowing ip for somreason. Inside my dash worried me so I went with a braded connection.
