Dougt
1967 1300B 1 Ton, 4x4, 266 CI V8 Rear brake lockup after running about 30 miles. Early on I replaced the master cylinder to address brake failure. Now I am thinking that might be the wrong master cylinder which might have a role in brake lockup. I am looking to replace the master cylinder and push rod. Not sure that what's in there now is the right one. And the original was unfortunately not saved. OEM part number for push rod is 356 200 C1. Not able to find that, but does anyone know what the length or any other specs on the push rod? Ordered new master cylinders from NAPA and Rock Auto, both of which corresponded to OEM number 356 039 C91 for the master cylinder, but neither comes with a push rod.
