crashradius
Hi folks
just received the LST for my 63 c1200 4x4, I will post as soon as I can get my scanner to function. Till then I have a few questions.
Front axle is a fa15 / d44 small closed knuckle 4.09 ratio
rear axle is a ra10 sgl r 4.10 ratio.
Transfer case is a t141 /np202
transmission is a t16/t98
s3 steering gear.
Questions as follows. Why are the front and rear ratios different?are there lockers available for the rear? Does any d44 locker work up front? Are different gearsets available for the rear
and what is the correct length for the pitman arm, it seems short and I run out of steering way before the wheels are lock to lock.
This truck has an enormous turning radius,way more than any vehicle ive owned. Thanks crash
s3 steering gear.
