the livewires cables use a female distributor terminal end for use with the male terminal distributor cap common to all delco hei (and clone) distributors. That cable end fitting will not fit an oem delco distributor cap unless it's been converted with adapters such as available from msd (so-called "power tower" of which n=5 pieces would be required).
