Hey michael, last night I pressure washed 35 years of road grime off of the tranny and transfer case so I could see what I was working with. All of the u-joints felt tight, but there was a little bit of play (maybe 1/8 inch) at the front output shaft. It also looks like there is a small amount of fluid seepage from the output shaft seal. I am guessing this is not normal. I am hoping to pull the transfer case this weekend so I can take pictures and see what I am going to need to rebuild it.
Also, I am new to 4 wheel drive so I have a question about shifting the transfer case. With the engine running, auto tranny in neutral, front hubs locked, and vehicle stopped I can shift the transfer case from neutral to 2wd no problem. But under these conditions I grind the gears and have to force the lever to shift into 4 low or 4 high. Is this normal? Should I be moving slightly when I try and engage 4wd? Or is this another problem caused by a worn transfer case?
Thanks for all the help.
